Strike two :(
Re: Strike two :(
Postby vigilant104 » Sun Nov 22, 2015 11:58 pm
jwd3ca wrote:I agree, which is why I opted not to exchange my heads for new ones. The TIME-SERTS look like they are extremely robust and I'm happy with my decision. That said, if one had to spring for the tool(s), it does represent a significant expense (~ $150 USD for the 12 x 1.25).The inserts themselves are negligible, < $2 each.
A tool like that might make a good start for a "Sonex Builders and Pilots Foundation Virtual Loan Locker". Pay the whole price up front, get $130 back when the tool is returned.
Mark Waldron
Aerovee, Trigear
vigilant104
Re: Strike two :(
Postby vwglenn » Wed Nov 25, 2015 3:36 pm
jwd3ca wrote:And I'm not sure I agree with your opinion of heli-coils being bandages, vwglenn. Have you had bad experiences with them? I'd sooner believe that they would be a lot more robust than plug holes badly threaded into aluminum . And who's to say the replacement heads will be necessarily better?
I haven't had any issues with them but I simply don't use them on the spark plugs based on other peoples experiences. Most of the guys I've known who used them said they didn't last very long (not a very large sample of guys 2-3 maybe). I heard one let go at a cruise-in. The engine kept running but the noise it made coming out and afterwards was terrifying. Plug and coil came out together. Possibly installation error? Ya never know with VW guys. Enough to convince me I don't want that to happen? You bet.
I don't think its a function of the helicoil itself but a matter of meat. Most VW heads crack between the valves over time. This is pretty much because of the small amount of metal between them. If you look at the amount of meat between the valves and the amount of meat between the plug hole and the valve (on a stock head) you'll see a very similar correlation between the distances. My assumption is the more meat you take out (ream it for the coil) the more prone the head is to cracking and releasing that coil or the plug. A helicoil is just basically a spring. If the metal around a helicoil weakens from a crack, so does the ability of that coil to hold the plug in place.
I will never profess to be an expert on the VW engine. I'm far from it. I just go with what I know/learned after driving one around daily for almost 20 years. My opinions are just personal opinions but they're usually based on practical real world experience. I believe the readers here can benefit from that but, like all internet message boards, your mileage may vary.
TIME-SERTS look like a better option and are more along the lines of a "case saver" which appear much more robust.
Glenn
Sonex #600
N889AP
vwglenn
Strike two :(
Postby Sonex1517 » Wed Nov 25, 2015 5:42 pm
We would be happy to add this to the tool loan list. I have to admit though, few have taken advantage of the program.
Chicagoland
N1517S reserved
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Re: Strike two :(
Postby DCASonex » Thu Nov 26, 2015 9:29 am
Robbie,
Please add my tools for grinding inside of fuel tanks for oops fittings to the foundation's tool rental.
DCASonex
