gammaxy wrote:I'm almost positive the metal is from inside the engine. It would be wishful thinking on my part to think otherwise :-), especially after 3 consecutive disappointing oil analysis reports that seem to be getting worse. My last analysis only had 9 hours on the oil and had more iron than the previous analysis with 16 hours and more than the first with 26 hours on the oil.
I also only recently switched to those silicone gaskets and am pretty sure I didn't accidentally install them with metal shavings.
The big mystery to me is why I only see the metal on the gasket? I'm going to at least drain the oil this weekend and see if I can find some more in the sump.
Nickasil or standard cylinders?
Your Chromium number is insanely high compared to mine even when my (Nickasil) cylinders and rings were failing.
Big flecks of metal in large quantities is obviously a big problem, but more often than not an issue is such that you won't see the metal other than through oil analysis. So although you found flecks on the gasket you may never find anything visible in the oil.
Here is what Lab One Inc publishes as a guide:
This trouble shooting guide is designed to assist the user in not only interpreting oil analysis test reports, but implementing appropriate corrective actions as well. It is not intended to be a definitive reference, but an at a glance guide to be used with other reference materials.
SPECTROCHEMICAL ANALYSIS – WEAR METALS
IRON (Fe)
Origin: Gears, Rings, Roller Bearings, Cylinder Walls, Camshaft, Crankshafts, lifters, Rust
Purpose: Because of its strength, iron is the base metal of steel in many parts of the engine. Since iron will rust, it is alloyed with other metals (i.e. Chromium, Aluminum, Nickel) making steel.
CHROMIUM (Cr)
Origin: Shafts, Piston Rings, Chrome Cylinders, Chrome plating on crankshafts
Purpose: Because of its strength and hardness, Chromium is used to plate rings and shafts that are usually mated with steel (softer). Chromium is also alloyed with iron (steel) for strength.
ALUMINUM (Al)
Origin: Bushings, Pistons, Turbo Charger, Compressor Wheels, Engine case
Purpose: Aluminum is a strong lightweight metal (smaller mass) which dissipates heat well and aids in thermal transfer.
COPPER (Cu)
Origin: Bearings, Bushings, Camshaft Thrust Washers, Connecting Rod Bushings, Oil Additive for Anti-wear/anti-oxidant. Valve guides.
Purpose: Copper is utilized to wear first in order to protect other components. Copper conforms well so it is used to seat bearings to the crankshaft.
LEAD (Pb)
Origin: Bearing Overlay, Low Lead Gasoline. Pb not done on recip engines because it is in the gas.
Purpose: Lead is a conforming material used to plate bearings. Lead is usually not reported as the lead from the fuel overshadows true lead from wear.
NICKEL (Ni)
Origin: Valve Stems, Valve Guides
Purpose: Nickel is alloyed with iron in high strength steel used to make valve stems and guides
SPECTROCHEMICAL ANALYSIS – WEAR METALS (cont’)
SILVER (Ag)
Origin: Bearing Cages (low friction bearings), Silver Solder, Turbocharger bearings and wrist pin
Bushings
Purpose: Silver is used to plate some components because it conforms well, dissipates heat and reduces coefficient of friction.
SILICON (Si)
Origin: External (dirt), Additive, Sealant's. Silicon can be an anti foam additive in the form of silicone.
FUEL DILUTION
Fuel dilution of crankcase oil by unburned fuel reduces lubricant effectiveness. The thinning of lubricant can lead to decreased lube film strength adding to the risk of abnormal wear. Fuel dilution is usually a product of poor leaning management although it can be caused by mechanical problems. Fuel dilution is not reported as it is an occurrence that happens during flight and can be burned off on the next flight. The tendency for gasoline to evaporate before the lab received the sample will generally result in it not showing up in a test.
SOURCE RESULT
Incorrect air to fuel ratio Metal to metal contact
Poor leaning technique Poor lubrication
Incorrect timing Cylinder ring wear
Defective injectors Increased fuel burn
Leaking fuel pumps or lines Decreased oil pressure
Incomplete combustion Reduced engine performance
Incorrect timing Shortened engine life
SOLUTION
Check fuel lines, worn rings, leaking injectors, seals, and pumps
Check timing
Avoid prolonged idling
Change oil and filters
Check quality of fuel
Repair or replace worn parts
INTERPRETING THE RESULTS TEST REPORTS
AND TAKING CORRECTIVE ACTION
Once all of the tests are complete, a highly trained Data Evaluator evaluates the results. The evaluation will result in (1) a statement that the unit is normal, or (2) specific maintenance recommendations will be made. The report recommendations are only one tool that can assist you in making your maintenance decisions.
RECOMMENDATION CATEGORIES
Normal
No explanation is needed for this category. Keep in mind that it is important to know that a unit is normal. This can save you unnecessary tear-down.
Abnormal
This category is followed by specific maintenance recommendations, or a notation that component wear is abnormal: there might, for example, be a recommendation to change oil and filters, and a comment noting that abnormal bearing wear is present. We are not telling you that it is time to tear down the unit. We are suggesting that you perform the maintenance suggested, and advising you that bearing wear is present. A second sample in a shorter time span might be requested. We do not recommend that you go into a unit on an abnormal recommendation unless you have discussed the report with the appropriate Laboratory Data Evaluator, your mechanic, engine shop or you have indications that the unit has a more serious problem than is apparent in the report. Again, your judgement must be based on all of the tools at your disposal, including our report, your knowledge of the unit and your experience. Remember, oil analysis does not preclude other regular maintenance practices such as checking screens, cutting open the filter and checking for excess filter debris or compression checks.
Critical
This is the category we use to indicate potential failure and a serious condition exists. A telephone call is made to the contact person and we will indicate the suspected nature of the problem and make a recommendation for maintenance action. Critical units require immediate attention.
Figures in grey are those that Need Close Attention: A serious problem could be developing and the unit should be closely monitored.
Re-samples: We will request a second sample to establish a trend whenever we have a potential “critical” unit with no previous history. If the wear increases, you will be advised of the suspected nature of the problem.
In some cases, the data will identify an obvious problem. For example, high levels of silicone usually indicate dirt or dust contamination, and the need to check air filters and the air induction system as well as alternate air doors if so equipped.
Sometimes however, the analytical data from an individual sample does not provide enough information to make more subtle judgments about oil or equipment condition. In these situations it is necessary to monitor the trends in analytical data over a series of samples to establish a wear trend pattern. By monitoring wear metals such as copper it is possible to detect the early stages of possible bearing failure. In most cases it can detect problem far enough in advance that it will allow for scheduling a bearing inspection at a convenient time, reducing or eliminating expensive equipment downtime and repairs.
The most common engine oil contaminant is silicon (dirt). Silicon (dirt) contamination is the most common form of contamination and causes serious engine wear due to its abrasive action against all moving parts within the engine. Silicon levels above 15ppm should be considered cause for inspection of the air intake system to locate the source of entry for the dirt and other airborne debris.
Wear metal analysis can indicate which engine components are wearing and if the wear is becoming significant. This information can make the difference between minor component inspections and repairs and major overhauls. Wear metal levels are provided by spectrographic analysis of the oil sample, indicate the element level in parts per million (ppm), of each of the common metals found in the engine: iron, aluminum, chromium, copper, nickel and silver, (and magnesium in turbine and jet applications).
Wear metal analysis requires more that simply plotting data on a graph. Wear metals can be generated from as many as a dozen different engine parts and locations making it difficult to identify the specific part that is wearing excessively. It is the knowledge acquired through years of experience and analytical training, that the analyst can draw upon, to provide the most accurate analysis possible for customers.
Oil analysis is best looked at on a trend basis. The first time that a laboratory looks at a sample, the analyst basis his judgement on experience and averages of other engines of the same make and model. The second sample can be compared with the first, but not until the third sample is a true trend formed. Very often people assume that the number we report in parts per million (ppm) are hard and fast numbers for each engine. There are so many variable factors to take into consideration such as; the time on the engine, the time on the oil, the flying conditions as in a acrobatic aircraft will show higher metals than another aircraft with the same engine flown normally. This would apply to crop dusting planes also. What oil analysis is telling us is when there is a deviation from what is normal for that engine, then there is a potential problem. This deviation has to be taken into account on a ppm per hour scale. A deviation of 20 % or more on a per hour scale will indicate an existing problem. A gradual rise in any element is usually a warning of a problem that is oncoming. Oil analysis should be done at each oil change to develop a trend for the life of the engine. By doing oil analysis on a new or rebuilt engine you can monitor the break in which can occur up to 300 hours. Most engines break in fine but on a rare occasion you can catch an engine that is not breaking in properly. Oil analysis can help you decide when an engine need to be overhauled. When an engine reaches TBO and is not being flown commercially, doing regular oil analysis, compression tests and 100 hour inspections can help you determine when it is time for overhaul.
