by Bruce593SX » Fri Nov 06, 2015 9:57 am
I have not run mine yet, but this may or may not help you....
In my case I had 2 mistakes in a row, both which gave me a tight engine... easy to know if you have an engine that is too tight, take off the prop and one plug out of each cylinder, can you turn the engine at all with just your hands on the prop hub? No? then too tight...
the first time I assembled my engine I had a HELL of a time with the bearing keepers (those damn tits I called them and still do!) Couldn't get them to all line up for anything... assembled the engine when I thought all was good. turning was tight, tight, tight. no way could I move the prop hub with just my hands. After a bit of research, thought better of it, dissembled the engine completely including new bearings (which of course means having the prop hub pressed off and re-assembling the crankshaft!). Saw definite evidence of round "dents" in one of the bearings where the bearing alignment pins where not in the right place when it was assembled. Got everything back together this time being excruciatingly careful of THOSE DAMN TITS! But guess what... still pretty tight... not as much as before, but pretty tight... Still plane not complete and engine not run.
Fast forward a year or so while other real life gets in the way of plane building and I get back to my engine. Something's not right, here we go again lets tear it down, including press off the prop hub (bought a new one for piece of mind since this was the second time the first one got pressed off. Probably didn't have too, but it was worth it to not have it nagging my brain later.)
After much head scratching and some reading on this forum, I discovered the problem this time. The bearings I had purchased where not radiused enough for the big ass racing crank that we run in our aerovees. Particularly at the main bearing nearest the flywheel (in the rear of our engine) where the crank needs to be pushed up against the bearing all the way. that rear bearing gets sandwiched between the crank and the thrust washers and my aftermarket bearing that I replaced to correct my LAST screw up wasn't butting up to the crank because it wasn't clearanced enough on the inside of the bearing for the crank radius!
So here is my advice. I believe you almost certainly have one or the other of the 2 conditions above. either way you are looking at a complete engine tear-down to diagnose and/or correct. I believe you are looking at a teardown either way as if it is issue number one above, the only way it will loosen up is by making metal, if it is symptom number 2, then it will also make metal but once it does, you will have incorrect end play on the crank causing all kind of other havoc.
Once you have bitten the bullet and have the bearings exposed, first look for the obvious signs of THOSE DAMN TITS making a depression in the bearings. You will see the pressed in little round dents that made me feel stupid.... then look at the inside edge of the rear main bearing, Does it fit tightly against the crank? is there a very narrow shiny polished area right on the edge of it where it was rubbing against the crank radius?? I have seen another report on this forum where the Sonex supplied bearings did the same thing. if that's all it is, and there is no evidence of the bearing keepers having been installed incorrectly, just file a radius into the main bearing until it will fit tightly against the crank, DON'T FORGET TO RE-DO YOUR END PLAY! and you should be good to go.
If its the keepers, then obviously it's new bearing time.... with all of the unpleasantness of pressing off the hub etc. For my it gave me a good excuse to buy a nice 20 ton press from Harbor Freight, so at least I got a new tool out of it....
When re assembling the engine, use the technique pointed out by another contributor to this forum, after you have the crank all settled in to one side of the case half, take the other half of the middle split bearing and rest it on top of it's mate. if you can rock it back and forth, one of the bearings is not completely seated. if it doesn't move, you are good to go. Now like me, you are quite adept at tearing down and re-assembling a Volkswagen engine!
Bruce Johnson
Sonex 593 AeroVee Turbo
Plans building near San Antonio, TX
