Cowling and Cooling
Cowling and Cooling
Postby Sonerai13 » Wed Nov 04, 2015 10:19 am
Recently we were made aware of a builder who flew his airplane without the cowling installed. I thought it would be appropriate to post a reminder to the group that this is NOT a good idea. The cowling forms the top of the cooling plenum. This forms the high pressure area above the engine that forces air down through the cooling fins on the cylinders and heads. Air is a fluid, and like all fluids, it seeks the path of least resistance. If the cowling is not in place there is no plenum formed and nothing to force the air down through the cooling fins. Thus, the air will simply flow around the engine and not through the fins and you have no control over what, if any, cooling is taking place. Your CHT may or may not show a problem, but there's no way to know if there are hot spots in other areas of the cylinders or heads. The only way to make sure you are getting complete airflow through the cooling fins is to fly with the cowl in place.
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Fortes Fortuna Adiuvat
Sonerai13
Re: Cowling and Cooling
Postby Rynoth » Wed Nov 04, 2015 11:26 am
Thanks for the reminder Joe. What about running without the cowling on the ground?
I recently made my first start tests and had the cowling off so others could watch for fuel/oil/smoke/flame and standby with a fire extinguisher. A friend of mine who is in A&P class said the teacher recently gave a lecture about this, saying that even on the ground, running without a cowling and baffles installed is very hard on the engine. He said for first start you should run for no more than 3 minutes without the cowling, check for leaks/issues, then always use the cowling going forward, ESPECIALLY on the ground.
Postby gammaxy » Wed Nov 04, 2015 11:33 am
Well, now I'm curious... how well did it fly?
Chris Madsen
Aerovee Sonex N256CM
Flying since September 2014
gammaxy
Postby Sonerai13 » Wed Nov 04, 2015 12:32 pm
Rynoth wrote:What about running without the cowling on the ground?
Running on the ground for short periods of time without the cowling is ok. You just don't want to run it too long, and only VERY briefly at high power settings. You have to do this in order to dial in the AeroInjector, but just use your best judgement and keep it to a minimum.
Joe Norris
Sonerai13
Postby Klimek » Thu Nov 05, 2015 10:09 am
For my first start up I installed a piece of sheet aluminum that fit from left to right baffle with a slight bend downward on each side and extending forward even with the front lower cowl opening seal area. It was drilled and clecoed to
each side baffle compressing the side baffle seals and the rear seal. It basically took the place of the top portion of the upper cowl forward of the rear baffle fence.
Being a ONEX, this also directed air over the oil cooler as well.
With this set up you can see everything that's going on. Cool!
Frank
ONEX 090
N1970T
37.00 hours and counting
Klimek
Location: Springdale, Ar....Northwest corner of the state
Postby paulonex » Thu Nov 05, 2015 10:14 pm
Joe's comments and concerns are valid
but
from an engineering / physics perspective, fluids nor electricity take the path of least resistance.
they take a path / flow inversely proportional to the resistance they encounter.
Just think of the furnace in your house, if the air took the path of least resistance all the air would exit out of one duct.
If you want to learn more google --- parallel circuits
paulonex
Return to Technical Write-Ups and FAQs
Users browsing this forum: Bing [Bot] and 5 guests
