90 degree oil drain valve
Postby N555NX » Thu Jun 30, 2011 7:14 am
I saw a picture somewhere with a 90 degree sump drain valve coming out the side drain port on the oil pan. Where can I get one?
Charlie
A&P, Avionics Installer, Comm Multi Instrument rated
N555NX (Reserved)
N555YX (Assisting on Waiex #21)
http://www.youtube.com/reichec
N555NX
Re: 90 degree oil drain valve
Postby N111YX » Thu Jun 30, 2011 9:05 am
See here...
http://www.aircraftspruce.com/catalog/a ... ickdv2.php
I have not bought one yet as it seems that it will interfere with the oil cooler baffling.
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1100 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby N111YX » Tue Jan 17, 2012 1:24 am
I did install the valve last oil change. I managed to break the metal oil cooler baffle so I just took it off. I run about 10F hotter which is perfect for winter!
During a new install, you will have to notch the metall baffle a bit for clearance for the drain valve.
I'm looking forward to my first drain after more 25 hours. Having the oil shoot out paralell with the ground is a bummer after a while...:(
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1100 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby fastj22 » Wed Jan 18, 2012 12:07 am
Damnit Kip, just when I thought I finished buying stuff for the plane, you chime in here and make my wallet lighter!
Postby N111YX » Wed Jan 18, 2012 1:18 am
You will thank me later... ;)
fastj22 wrote:Damnit Kip, just when I thought I finished buying stuff for the plane, you chime in here and make my wallet lighter!
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1100 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Return to Jabiru
