TaxMaverick wrote:"Installed weight" is a term I may be using incorrectly. I assumed fluids, engine mount and so on are included. "The engine has an installed weight of 224lbs," is exactly what the SeaRey owner said to me.
The engine weight question I saw in Jan's Yahoo group. Classic answer: "178 lb [period]." Try listing what you would like included, e.g., fluids, muffler and so on.
Sonex looks like a risky airframe for this engine. I plan to put it in a CH 750, where a little more weight and power than a Rotax would be perfect.
For Sonex, I think you want a light-weight, direct-drive engine.
I read somewhere direct-drive engines are better for cruising. High-RPM, geared engines are good for delivering a lot of torque to get bush planes off the ground.
I plan to build a high-speed cruiser after my bush plane. I would love to use the Viking for both. But from what I have read, you want a direct-drive engine for high-speed cruising. (I could be wrong. I do not have first-hand experience trying both.)
A complete engine, with its accessories, is included in this weight. Supporting
systems such as coolers, etc are not included because every installation is
different.
The forever ending, always asked question of what is, or is not included is an
airframe question. We build engines. The engine weight is 178 lb. It is for
the airframe manufacturer, to figure out how to keep supporting systems as
efficient and lightweight as possible.
If you need complete installation weights of different airplanes, use complete
airplanes, and their weight and ballance info. There is one of these on the
CH-701 page of the web.
Jan
Andy Walker wrote:I would be a bit surprised if many 3300 engined Sonex are less than 200lb FWF. Once you include baffles, ducting, lines, motor mount, electrical wiring, battery, etc...it just seems hard to believe all of that will come in at less than 22lb.
Users browsing this forum: Google Adsense [Bot] and 1 guest
