by fastj22 » Fri Oct 16, 2015 10:50 am
I've got around 200 hours behind my Aerocarb and here are my observations.
This summer 4 Sonex flew to an airshow in Colorado. All Aerocarb equipped. The planes sat on the line for 5 hours heat soaking in the 100 degree sun. My cowl allows the top to hinge open and I left it open to allow the crowd to peer inside. It also let all the heat out. The other Sonex stayed buttoned up. One sonex was based there and didn't depart after the show.
I was first in line to depart and after a fairly long taxi, was finally cleared. I as running AvGas, gascolator. I had burped my system (burp tube) before taxi yet was still feeling some burps as I launched but it cleared before the end of the runway.
The second sonex, also with burp tube, launched behind me. AvGas, gascolator. He burped all the way down the runway and for a few miles after too. He radioed to me that he was considering turning back but then it cleared.
The third sonex, no burp tube and running auto gas, no gascolator, was burping so bad on departure he returned to the airport immediately. He ended up spending the night with the other sonex flyer and departing the next morning.
Burping is clearly related to heat soaking and fuel type. Auto gas burps more than AV Gas. If you are doing multiple stops, you will accumulate heat in the system on every stop. You can mitigate many factors, but in the end, without a circulating system, a pressurized system or carburetor fuel bowl to absorb the bubbles, you will burp.
For a number of reasons, I'm installing a Rotec with a circulating system.
