Bryan Cotton wrote:What I have done on other motors for a similar situation is to turn back from TDC and feed a length of closeline in through a spark plug hole. It does not compress and you can tighten or loosen the nut. Not sure if this will work here as I have not built my aerovee yet.
Arjay wrote:Can't you just put the crank in a vise to hold it while you tighten down the bolt?
Gripdana wrote:I did mine when the flywheel was installed and secured the flywheel.
mike.smith wrote:Arjay wrote:Can't you just put the crank in a vise to hold it while you tighten down the bolt?
Most surfaces of the crank are critical wearing surfaces. Would not be a good idea to use a vice. Besides, half the weight of the engine is in the crank. It's heavy! Tough to hold such an animal in the average work bench vice.
