by Bryan Cotton » Mon Oct 12, 2015 10:50 pm
Ken,
Glad to help. I made the mistake of too much polish too. We all learn.
One key tip, at least one that works for me: I take a small dab and smear it around as much as possible with my finger. Then I take the buffer and blip it at a very slow speed to finish sreading out the polish. When you have some shine going, this technique will make the area look tarnished. In fact the polish is just spread very thinly and uniformly. Then lay into it and bring the shine back. You don't get the same cues on your first pass but after a while you know what to do. Also, I like to polish a small area, and center the next pass on the edge of the prior pass. That way even though I am doing 3 passes, overlap means the metal sees the buffer 6 times. Each application does not take long but there are a lot of them.
When I get to C it is a lot more relaxed. You are de-scratching the F9 work.
