Tighten those bolts up pretty darn tight. Your going to be inflating those tires about 20 higher than the max pressure stamped on the side of the wheel. About 45-50 psi.
The only folks I've ever heard about breaking wheels were those using lower than normal tire pressure and minimal torque on the bolts.
As a side note, if your tires get below about 35lbs you run the real risk of moving the tire bead on the wheel during hard braking and then you get an almost instant flat when it rips the stem off the tube.
Tighten them up tight and run good solid tire pressure.
Users browsing this forum: Google [Bot] and 111 guests
