The engine has 90% money back guarantee, during the warranty period of one year.
TaxMaverick wrote:I called the Searey owner, Tom -- his number is in the Barnstormers ad. He is a real nice guy.
He says the engine itself is fine. His problems are as follows:
1. As mounted on his SeaRey, the engine moves the center of gravity too far aft. He had to put a 30lb weight in the nose to get it to fly straight.
2. There is an issue with the engine in the pusher configuration. I didn't understand exactly what he said. But, it sounds like the large wings on a SeaRey interfere with the airflow to the prop, robbing it of some power. (420lbs of thrust is what he says he was getting, if I remember right.)
3. The installed weight of the engine is 224lbs. He thinks it is too heavy, especially with the power reduction caused by the engine being in the pusher configuration.
He says he thinks the engine would work fine in a tractor-configuration plane, like the CH 750. (Personally, I would think it is too heavy for a Sonex. I also read somewhere -- I think on the Viking site -- the current gearing is not optimal for a high-speed cruiser, like the Sonex.)
"Buyer beware" with Eggenfellner is another thing he said. He says Eggenfellner will bend over backwards for you as long as you go along with what Eggenfellner wants to do. But, he says Eggenfellner turned on him when he decided he did not want anymore re-engineering done on his pristine new SeaRey. He asked Eggenfellner for a refund. But, Eggenfellner refused.
The YouTube video was taken down by Eggenfellner after the SeaRey owner posted a comment mentioning some of the above.
I still like the engine and would like to buy one. I certainly hope it does not disappear as an option.
- Eggenfellner, reasonable people understand things are not likely to be magically perfect with the first installation on a particular plane. Hiding this is not necessary. Learn and improve.
fastj22 wrote:You won't see your post on his yahoo forum. He won't respond or allow anything negative. It happened with his Subaru forum too. Which is now idle for the last 3 years.
A little more research found an alternate Yahoo forum for those Subaru customers seeking help with Eggenfellner problems. Its restricted to those who have the engines so difficult for us to see what issues are being discussed.
He's not well received in the RV community. I think I know why now.
People are asking why the SeaRey supposedly did not fly as good with the Viking
as with the Rotax 914 turbo.
The Viking just recently had a 400 rpm / 60-80 lb of additional thrust
introduced through a tubular intake manifold. This was never tested on the
SeaRey.
The SeaRey LSX model is as much as 150-200 lb heavier than the earlier models.
It is also stronger / has a bigger / heavier tail.
SeaReys in general have an aft CG, we are now moving the engine forward 2"
The SeaRey designer flew this particular airplane, did not sence much of a CG
issue, said the airplane / engine combination has lots of promise.
The pusher Viking SeaRey installation is naturally heavier than in a
conventional tractor layout due to a larger radiator and fan assembly at about
15 lb more.
The excitement surrounding this is that we now will do a second installation,
using what we have learned so far, and really hit the nail on the head. The
changes are:
Working with a builder that has previous SeaRey experience
Shift engine forward 2"
Move engine up 1"
Have oil tank on top of the flap tube for better looks.
More room for the quiet 3 chambered muffler
Prop extension for better airflow into prop
Tubular, performance enhancing Viking intake manifold
ECU software changes for additional power.
There was also a question from a Sonex builder about VW to Viking weights. 2 x
701 customers have gone this way and the airplanes have similar CG but some more
weight. Some of this weight is due to a header tank, not needed on the Sonex
due to it's single fuel tank
We will shortly demonstrate SUPERIOR light sport engine performance with an
RV-12
Jan
Users browsing this forum: Google Adsense [Bot] and 0 guests
