by toddosborne » Thu Sep 24, 2015 2:06 am
I just installed the fiberglass tip on my vertical stabilizer. When drilling and fitting everything was great. When I installed it, it looks like a hole must have gotten a little out of place because now there is a "hump" in the fairing between the back of the rear spar and the first hole in the tip extension. I really don't want to take the skin off to figure out the problem, and not terribly confident I'd be able to fix it anyway without replacing at least the tip extension. Is there a better way to basically shrink the fiberglass? Heat? Cut a small section out with a dremel and patch it? Thanks,
Todd
Todd Osborne
Sonex #0416 (Building Sport Acro)
Oak Island, NC
