Exhaust Stud Removal
Postby Sonex374 » Thu Sep 17, 2015 4:31 pm
Anyone else experienced issues removing the threaded studs from the exhaust ports? Mine seems to have had all available Loctite used. I have twisted one off and now trying to decide how to best remedy this.
I cannot understand why they are even in a new head which Sonex knows is going to need bolts rather then studs.
Rutter
N374WR (Reserved)
Sonex tri-gear
Polish
Aerovee
Sonex374
Re: Exhaust Stud Removal
Postby wlarson861 » Thu Sep 17, 2015 6:50 pm
I got most of them out with a pair of channel locks, one I had to use a small pipe wrench to get it to yield.
Bill Larson
N861SX
wlarson861
Postby rizzz » Thu Sep 17, 2015 8:35 pm
Sonex374 wrote:Anyone else experienced issues removing the threaded studs from the exhaust ports? Mine seems to have had all available Loctite used. I have twisted one off and now trying to decide how to best remedy this.
They are in there because that's how Sonex buys them from their supplier (I believe that's Mofoco now, it used to be CB Performance).
Sonex just machines (or outsources machining) the heads for dual ignition and sells them on to you, they don't bother removing the studs, possibly because depending on your application you might want to keep them in place. (remember the AeroVee is not only sold to Sonex customers, other airplanes might require different exhaust systems and perhaps prefer the studs instead)
I have a (non AeroVee) VW engine also with the same Mofoco heads (mine were machined by Hummel) and I have an old set of 4 separate exhausts rather than the 2-in-1 system, thus I was able to leave my studs in place and use the standard VW copper nuts to install the exhausts.
My problem is opposite to yours though as I was removing one of the exhausts recently the stud came out with the nut, not enough locktite perhaps? Anyway, not a drama to fix that issue :).
rizzz
Postby jjbardell » Fri Sep 18, 2015 7:37 am
I removed all my studs with double nuts. It popped everyone of them off with ease.
N83LJ - Sonex #0864 (SOLD)
jjbardell
Postby Sonex374 » Fri Sep 18, 2015 7:58 pm
Well out of the 4 three need to be drilled used double nut method soaked numerous times with pb blaster thru talked with some heat and use candle wax. Did not work two twisted off one nuts stripped threads, then used vise grips to no avail. These puppies must have been epoxyed in. Now drilling out one down and saved 2nd in process.
I'm a not a happy camper with this. For something new never run this should not occur. The opposite head was easy.
Rutter
N374WR (Reserved)
Sonex tri-gear
Polish
Aerovee
Sonex374
Postby SNX1508 » Fri Oct 02, 2015 5:30 pm
Anyone know the torque value for installing the exhaust pipe bolts in the cylinder head? For whatever reason this is missing from the torque values in the AeroVee assembly.
Terry
Terry
Sonex #1508
N296SX
AeroVee #0736
Tail Dragger
http://www.mykitlog.com/SNX1508
SNX1508
Postby wlarson861 » Sat Oct 03, 2015 12:41 am
I had one stud that would not budge, double nut, channel locks, nor large vice grips would turn it. Finally tried a small pipe wrench, it would cut into the stud and not slip and it turned right out
Bill Larson
N861SX
wlarson861
Postby Sonex374 » Sat Oct 03, 2015 8:37 am
Terry the torque values are in manual in a chart near the last section they are based on size not .specific to location I think
Rutter
N374WR (Reserved)
Sonex tri-gear
Polish
Aerovee
Sonex374
Postby SNX1508 » Sat Oct 03, 2015 3:43 pm
Torque chart in AeroVee manual does not list the exhaust pipe to cylinder head bolts.
Terry
Terry
Sonex #1508
N296SX
AeroVee #0736
Tail Dragger
SNX1508
Postby Sonerai13 » Sun Oct 04, 2015 10:25 am
There is no specific torque value for the exhaust bolts. This is because there are several different gaskets that may be used, and some people put high temp RTV on the gaskets and some don't. In other words, too many variables. Most people over-tighen the exhaust, which will bend the ears on the flanges and cause leaks. Just bring them up until you see a little compression of the gasket and let it go at that. They don't seem to have a tendency to come loose, so you should be fine.
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Fortes Fortuna Adiuvat
Sonerai13
Users browsing this forum: No registered users and 24 guests
