Oil Pressure and first start
Postby caymancraig » Mon Sep 14, 2015 12:01 pm
Hello all, I'm hoping to do my first engine start Wednesday. I tried removing the lower plugs and spinning the prop by hand and got no oil pressure. Does an AeroVee create pressure by spinning the prop or only when it fully runs?
Also, any advice about the actual first and second running since it will be done in the driveway? Low RPM or ??? I know to watch mainly head temps and would not think I would want them above 350 on this first runnings.
Craig Mock
Waiex - N239YX
Tri-gear, turbo, Dynon panel
Naples, Fl
caymancraig
Re: Oil Pressure and first start
Postby Rynoth » Mon Sep 14, 2015 2:09 pm
caymancraig wrote:I tried removing the lower plugs and spinning the prop by hand and got no oil pressure.
From the Aerovee Manual:
"With the fuel off and ignition switches off, operate the starter until oil pressure registers on the oil pressure gauge. Note: If no oil pressure registers, the oil pump may need to be re-primed with white lithium grease. Also, check the electrical connection of the oil pressure sender."
I highly doubt that spinning the prop by hand would turn the oil pump nearly fast enough to prime or create pressure... would need several hundred RPM.
Postby Sonex1517 » Mon Sep 14, 2015 4:03 pm
I was advised to remove the oil pressure line connection, turn the prop by hand, and see if oil came out.
It didn't.
I re primed the pump as described above, reassembled the pump and repeated the step. I got oil.
On first start the pressure registered immediately.
Your mileage may vary.
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Postby caymancraig » Mon Sep 14, 2015 9:17 pm
Running the starter did it.
Any advice on which needle to start with for the turbo engine? I can't seem to find a reference anywhere.
Craig Mock
Waiex - N239YX
Naples, Fl
caymancraig
Postby Rynoth » Mon Sep 14, 2015 10:04 pm
caymancraig wrote:Any advice on which needle to start with for the turbo engine? I can't seem to find a reference anywhere.
I wish I could cite a source, but I'm fairly the certain that the factory is running the 2.5 needle.
Postby Sonex1517 » Mon Sep 14, 2015 10:55 pm
I also have no source but believe the same. I think they use a 2.5.
Chicagoland
N1517S reserved
Aero Estates (T25)
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Postby wlarson861 » Tue Sep 15, 2015 12:11 am
The needle size was mentioned in one of the posts here or an article. I just don't remember where I learned it but I used the 2.5 needle from the first start of the turbo and am still using it. You tune the carb the same way as normally aspirated. full power(40 inches MAP) peak lean and note EGT then full rich and look for 90 to 100 degree drop; no more no less. The #2 may work but I didn't even try, since the factory said #2.5 that's what I did and it seems to work.
Bill Larson
N861SX
wlarson861
Postby Waiex 176 » Tue Sep 15, 2015 1:41 pm
I am using a 2.5 needle with my turbo. If you look in the turbo kit thread you will find this statement from Joe Norris.
The needle in our turbo's AeroInjector is not modified in any way. It's a stock 2.5 needle right out of the box.
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Fortes Fortuna Adiuvat
Sonerai13
John
Waiex with Aerovee Turbo
Waiex 176
Users browsing this forum: No registered users and 31 guests
