W03 (normal) or W22 (acro) aileron
Postby Bryan Cotton » Wed Sep 02, 2015 9:27 pm
All,
How the heck did you set these rivets by the aileron counterbalance?
Postby Sonex1517 » Wed Sep 02, 2015 9:38 pm
Ugh. Worst rivets on my airplane. I really want to know how people did this because I have 2 left to pull
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Re: W03 (normal) or W22 (acro) aileron
Postby MichaelFarley56 » Wed Sep 02, 2015 9:42 pm
You don't want to see mine! I never had much luck and to say the least, those few rivets on mine turned out terrible.
The only way I know how to set those with any reliability is to use some sort of hand rivet squeezer intended for hard to reach areas. Or you can do what I did and take a Harbor Freight hand puller and grind it down to the point you can use that! Those are tough ones to set!
Waiex #0056 - N569KM (sold)
Onex #245
Postby rizzz » Wed Sep 02, 2015 11:24 pm
Get yourself a PRG 410 hand rivet gun, because the thing is that slim, you'll be amazed the awkward places it can be used to pull rivets where no other rivet gun can. (I believe I did these with that gun, possibly in combination with a small aluminium wedge I made with hole in it)
You can't buy em new anymore but they regularly come up on ebay, like now:
http://www.ebay.com/itm/Vintage-Pop-Riv ... 1062852608
http://www.ebay.com/itm/United-Shoe-Mac ... 21019d45a2
http://www.ebay.com/itm/Vintage-United- ... 35f0c68ecd
http://www.ebay.com/itm/VINTAGE-1963-PO ... 4aef9263bc
Seriously, this one is a great one to have in your toolbox!
Edit: just looked back through my log and I can confirm, I did these with the PRG 410, in fact, this was the point when I bought it, I've used it many times after, trust me:
http://www.mykitlog.com/users/display_l ... 79&row=220
rizzz
Postby Bryan Cotton » Thu Sep 03, 2015 12:09 am
Thanks Rizzz, got one on the way.
Postby Direct C51 » Thu Sep 03, 2015 12:25 am
Here's a picture from my builders log of how I set mine. They turned out pretty good.
https://sonex528nm.wordpress.com/#jp-carousel-211
Direct C51
Postby ccm » Thu Sep 03, 2015 3:30 am
I used this riveter: http://www.averytools.com/prodinfo.asp?number=P26A. It was much less expensive when I bought it though!
Craig Miller
Sonex 1526
Standard gear, AeroVee
http://kdmiller.unospace.net/mediawiki/index.php?title=Main_Page
ccm
Postby DCASonex » Thu Sep 03, 2015 8:30 am
Wish this forum had good way to quickly post photos, but I made my own close quarters puller from common $10 hardware store unit. Ground off everything forward of the barrel, and enough to expose about 1/3 of inside of the barrel at nose. Welded stiffener wedge to back side. That puller can fit very close to walls. To get closer, I have a small wedge with a mandrel sized hole in it welded to section of welding rod as a handle. That wedge holds rivet heads flat when rivet puller held at slight angle. In effect pulling the mandrel around a slight bend which allows setting rivets with near zero clearance to wall.
DCASonex
Postby Rynoth » Thu Sep 03, 2015 8:48 am
I don't remember exactly, but chances are I used my handy little wedge piece that worked very well for 100's of hard to reach rivets. Basically a small wedge piece (about 30 degree wedge) of aluminum with a hole in it for the mandrel. This lets me insert the rivet, slide the wedge on the mandrel, bend the mandrel about 30 degrees then bring in the rivet gun at that angle. Bottom of the wedge stays flush against the rivet.
Also, here's a previous post on the subject:
viewtopic.php?f=21&t=909&p=6718&hilit=aileron+rivet#p6718
Postby Sonex1243 » Thu Sep 03, 2015 8:27 pm
A little late, but, I picked this one up at a local hardware store a while ago. Read about it on the Yahoo site, I think. Hope it works when the time comes.
Ken S
SONEX #1243 N424SX (reserved)
Tail complete, wings done
Fuselage on gear
Jab 3300 received!
Sonex1243
Return to Sonex Plans
