MichaelFarley56 wrote:Now that AirVenture 2015 has wrapped up and everyone has (hopefully) made it home safely, I wanted to offer a quick summary of my trip this year as it was the first long trip I’ve made with the turbo AeroVee. I plan on writing a more detailed report for the next Foundation newsletter, but I got a lot of great turbo related questions while at AirVenture so I thought a quick summary would be in order.
First off, I’m happy to report that the engine ran beautifully the entire time. I never had a single hiccup, hesitation, sputter, etc. the entire duration of the trip. Before I left Ohio I had only been able to run the engine around 12 hours, so I was also hoping to use the trip to keep getting time on the cylinders and help continue the break in process. As a result I was still forced to keep the mixture pretty rich for low cylinder head temps but I was happy to burn a little extra fuel to keep everything running nice and cool. The only item to address at this point is my oil pressure; prior to adding the turbo my oil pressure was rock solid at 48-50 psi, but after adding the turbo it now generally runs around 40-42 psi. It’s still “in the green” and I knew it would be a little lower due to the hot temperatures keeping my oil in the 170-180 degree range (I briefly saw as high as 198 on a climb but after I leveled off it came back down to 175) but I’d still like my oil to be at least in the mid 40’s psi wise.
On the flight up to Oskhosh, I flew as a flight of 2 and we left mid-morning the Saturday before the show. Due to the low ceilings and visibility we were forced to stay below 2500’ MSL the entire trip and had to endure the hot air temp the entire way. The wind was not in our favor either so we ended up making two stops for fuel, ultimately arriving at Oshkosh around 1:30 p.m. local time.
At these low altitudes I was running the engine around 30” MAP which gave me around 3150 RPM, 130-135 MPH TAS, all while burning 7 gallons per hour.
The good news was that the CHTs never got over 385 in climb and were steady right at 355-360 degrees in cruise. I am currently using a Prince P-Tip prop that is 54x50” which seems to be slightly pitched more for climb which was nice on takeoff. Between myself, all the camping gear I could carry and full fuel, my takeoff weight was right at 1100 lbs. and even with the really hot air temps, my initial climb rates were around 700 feet per minute. Not too shabby!
On the return trip home, I was able to shed some of the camping gear and climb a little higher so naturally my cruise numbers were a little better. When running at 4500’ MSL and around 100 lbs lighter, I ran the engine at 30” MAP which gave me 3200 RPM, 140 MPH TAS, and fuel burn was slightly lower than before. CHTs were all very steady at 350 degrees with an average EGT of around 1200 degrees.
Overall, I’ve been thrilled with the turbo addition to the AeroVee. In my opinion the engine runs much smoother and stronger than before, and climb rate has been drastically improved. Using the Prince P-Tip 54x50 I can get some really excellent climb rates while still getting respectable cruise speeds. It’s really nice having all CHTs run within 5-7 degrees of each other and EGTs are normally within 15 degrees of each other as well.
Stand by for a more in depth report in the next Foundation newsletter, but if you have any questions in the meantime, please let me know!
mike.smith wrote:FYI, my oil pressure has been around 32 psi for the 100 hour life of the engine. VW folks say that 10 psi per thousand rpm is good. Sonex said as long as that number does not begin to decrease, I am fine.
Users browsing this forum: No registered users and 59 guests
