people with force a one hub
Anything related to props
Postby Johns » Tue Jun 09, 2015 6:45 pm
Did any of you have to modify the indent on the back of the wooden sensenich prop after switching to the force one hub? The original prop I took off had some more removed from said area. Wondering if this is the norm.
John
Johns
Re: people with force a one hub
Postby vigilant104 » Tue Jun 09, 2015 10:10 pm
John,
My plane has an Aerovee engine and was fitted with a Force One hub and a Sensenich prop. I didn't build it so I don't know if the prop was modified (I doubt it). Can I take measurements or send you a picture that would help? Can you tell where and why the prop was altered?
Mark
Mark Waldron
Aerovee, Trigear
vigilant104
Postby Gibbsfamily1 » Wed Jun 10, 2015 1:03 am
I was the original builder of Marks plane. If you are switching from an AeroVee hub to a force one, yes you have to modify the prop to allow for the larger centering section on the force one. I also modified the force one hub to accept the AeroVee prop lugs. Worked well.
Gibbsfamily1
Postby vigilant104 » Wed Jun 10, 2015 11:15 am
Gibbsfamily1 wrote: Worked well.
Still does! Thanks, Jay.
Mark Waldron
Aerovee, Trigear
vigilant104
Postby Johns » Wed Jun 10, 2015 2:41 pm
Yes, that's what I'm talking about. How did you go about enlarging the center and keep it centered so there is no wobble?
John
Johns
Postby Johns » Wed Jun 10, 2015 2:59 pm
Also, where can I get the Aerovee prop lugs. The person I bought the plane from didn't register with Sonex so I don't think I can either.
John
Johns
Postby DCASonex » Thu Jun 11, 2015 9:03 am
Johns wrote:Also, where can I get the Aerovee prop lugs. The person I bought the plane from didn't register with Sonex so I don't think I can either.
John
John, Would not make that assumption about not being able to register with Sonex until you check with them directly. The small fee is worthwhile for the support available.
David A. Sonex # 1327
Postby vigilant104 » Thu Jun 11, 2015 9:47 am
DCASonex wrote:The small fee is worthwhile for the support available.
+1!
Mark Waldron
Aerovee, Trigear
vigilant104
Postby Sonex1517 » Thu Jun 11, 2015 10:13 am
John
Absolutely!
325+ hours
Postby Johns » Thu Jun 11, 2015 6:12 pm
Hi guys, seems like everyone thinks I might be able to register. I will have to contact them and find out.
After giving it some thought I was able to modify my prop. Haven't started it yet but it tracked true using a block of wood for guidance.
Thanks for the replies, John
Johns
Return to Propellers
