Master Contacter
Master Contacter
Postby wlarson861 » Wed May 13, 2015 12:26 am
I am doing the Turbo upgrade to Sonex 0861. The only "convenient" place to relocate my master contactor is on the engine mount with a couple of hose clamps and some Silicone tape around the motor mount. I don't know if that violates any long held conventions or not? If I mount the contactor there I can use most of my wiring from my original set up. Anyone see a problem with the master solenoid not on the firewall?
Bill Larson
N861SX
wlarson861
Re: Master Contacter
Postby Bryan Cotton » Wed May 13, 2015 7:31 am
Bill,
I think if it survives the extra bit of vibes there is nothing wrong with it.
Postby avee8r » Wed May 13, 2015 9:25 am
That's what I did as I've seen it on vintage planes. It works fine.
Happy Landings
John
N50NX
avee8r
Postby tonyr » Wed May 13, 2015 6:02 pm
My only concern would be the contactor rotating around the tube due to vibration or clamp failure, and the terminals shorting out on something.
Another place to mount a master and/or start contactor is on the side and front of the fuel filler bay.
A couple of nutplates on the inside would have plenty of bolt clearance from the tank neck. Just locate them low enough so they don't interfere with a future drip tray surrounding the filler.
Sonex #813
First Flight... 4 Oct 14
298 hours having fun!
tonyr
Postby wlarson861 » Thu May 14, 2015 12:38 am
Thanks guys. I went ahead and placed the contactor on the engine mount, There are several wraps of silicone tape to protect the mount. the terminals are both booted and where it sits even if it spins it wont contact anything. With the heavy gauge wires I don't think it will move even if i removed the clamps. Oh well, another experiment.
Bill Larson
N861SX
wlarson861
Postby Bruce593SX » Fri May 15, 2015 10:59 pm
I bolted mine to the battery box
Bruce Johnson
Sonex 593 AeroVee Turbo
Plans building near San Antonio, TX
Bruce593SX
Postby Xenos50 » Wed Dec 28, 2016 11:27 pm
I bolted mine to the battery box as well (on a side). My engine is not Turbo AeroVee though, but Revmaster 2300.
I have a question regarding the contactor being pretty hot in about 20-30 minutes after turning the master switch "on". I can briefly touch it, but cannot hold my finger on the body of the contactor. The bottom of it is hotter than the top. Is it normal? I conducted a test having it "ON" for 2 hours, it did not burn yet. Maybe it is normal, but I did not expect it to be so hot. Mine is s701-1 from B&C. I would appreciate any information about this. Thanks!
Xenos50
Postby gammaxy » Thu Dec 29, 2016 12:53 am
Your master contactor serves as a ~10 watt heater due to the 15ohm coil (12v system/15ohm = 0.8 amps; 0.8 amps ^2 * 15ohm = 9.6 watts).
I use an automotive relay instead of a contactor--it only draws about 0.15 amps through the coil, but it can only handle 40 amps and can't be used to completely isolate the battery from the circuit.
Chris Madsen
Aerovee Sonex N256CM
Flying since September 2014
gammaxy
Postby GordonTurner » Thu Dec 29, 2016 8:52 am
Hi Chris
How do you control the power that goes to your starter? Happen to have a wiring diagram?
Gordon
GordonTurner
Postby Xenos50 » Thu Dec 29, 2016 11:23 am
Thank you Chris.
Xenos50
Return to Electrical System
