by fastj22 » Mon Mar 16, 2015 8:55 am
I've done both, installed the ops in my plane and replaced a tank in anothe Sonex.
The in plane fix is a pain, use a dremel to dress the new hole and a long hinge pin to fish the fitting to the hole from the filler.
To replace a tank, you must remove the rudder peddles, the panel and the tank straps. Lots of work hanging upside down in the foot well either way.
I agree the stock tank fitting design is bad. Sonex should mold in fittings with much larger surface areas to prevent spinning.
