Here I am sawing out my second half-hole for the saddle fix. I used the 3/4" holesaw the first time and it was too sloppy. Whipped out my 11/16" holesaw (I am the Holesaw King) and got a slightly small half hole which I dremel sanded up.
![Image](http://i198.photobucket.com/albums/aa72/Aerowerk/AA976DE5-BB84-4785-BE7D-FEA8D618D329.jpg)
Came out good. Not bolted in yet.
![Image](http://i198.photobucket.com/albums/aa72/Aerowerk/E554070E-AB75-4331-9725-DB2C8D58FDEF.jpg)
Here I have tacked on my repair sleeve for the tailwheel pivot.
![Image](http://i198.photobucket.com/albums/aa72/Aerowerk/D50FF14E-18FE-4A61-97DF-46E21BFA03A9.jpg)
Never lick metal when it is that color. I did get it welded up, and the pivot seemed true when I had it tacked. Welding is not a skill that improves with abstinence. Here I am obscuring the weld with the torch, in case EAA national ever looks at these pictures. If they saw that weld my chance for a Tony Bingeles award will go right to zip.
![Image](http://i198.photobucket.com/albums/aa72/Aerowerk/50C91F29-78EC-4A48-B049-90CA5BF42C5D.jpg)
Since I booted the harley golf cart out of the weld area I took it for a spin after. Helps to run it once in a while in the winter.
