matthewurban wrote:What would you guys suggest as a good alternative?
matthewurban wrote:= would that be a problem if I choose to just alodine the parts before final drilling so I can start riviting right after putting everything together? !
daleandee wrote:matthewurban wrote:What would you guys suggest as a good alternative?
Have a look at ACF-50. Amazing stuff used by the government and the airlines. Aircraft needs to be retreated every couple of years but treatment on a Sonex would be easy once you had the equipment. I've used this stuff in the aerosol cans and it is quite amazing:
http://www.aircraftspruce.com/catalog/pdf/ACF-50-BROCHURE.pdf
If you're going to paint you should do that before applying ACF-50 as it will wick out of every crack and crevice for a while after treatment.
FWIW,
Dale
N319WF
