OK. So what do the regs say?
fastj22 wrote:vwglenn wrote:I would be OK with the site tube if it registered three or four gallons. Then it would serve some panic button type purpose. To be honest though, I just don't see the point if the lowest it will register in my plane is 6. That's closer to 1/2 a tank than empty.
Thats what I realized when I had installed the as plans sight tube and started flying. I removed it simply because it provided no benefit and increased failure modes. Down the front hanging below the panel might work better, or just ducking your head under the panel to see the tank would work as well.
I use an FT60 flow transducer and my MGL xTreme fuel totalizer with great results. (However the first one lasted only 100 hours) The Princeton probe died after I used MoGas. The Belite fuel level transducer is incompatible with the MGL. I also use a timer as a backup. And a calibrated dip stick during pre-flight.
NWade wrote:As far as whether the sight-gauge is required: Flying Magazine answered this in a 2010 article/mailbag segment. I've heard this elsewhere, too (...that FAR 91.205 only applies to standard-category aircraft, not Experimentals). If you're going to fly at night or with an IFR-equipped aircraft then most people say that you become subject to more-stringent requirements, similar to what standard-category aircraft must carry for day/night VFR instrumentation.
DCASonex wrote:I had sight tube routed along edge of panel and down side of fuselage. gave readings for bottom of tank. BUT I removed it after two years when found tubing had gotten so hard it was brittle. It actually snapped in half when removing it.
kmacht wrote:I would love to watch a video of someone trying to lean over in flight and view the fuel tank. Even better, try it with a passenger on board as well. It is hard enough to do while on the ground never mind while strapped in and flying. I suspect you will quickly find yourself in an unusual attitude.
#54
vwglenn wrote:gammaxy wrote:Why you don't think it's accurate?
Well, the way mine is set up, the sight tube is only good until there are 6 gallons left in the tank. That's the point at which the fuel gets too low to read. I was always trained to never trust a fuel gauge and I've always relied more on a timer and fuel burn.
JerryCPP wrote:It is a very simple matter to plumb in a small ball valve at the tank to shut off the site tube should it rupture. The weight penalty is a few grams, and it will give you the peace of mind that if there is a problem, you can shut off the flow quickly and easily. Jerry Loeffelbein, Sonex N1320X
