Rynoth wrote:Bryan, would the aluminum stand up to the heat of the exhaust pipe when there's no airflow (cabin heat turned off)?
Bryan Cotton wrote:Disclaimer: I have never made a heat muff. Yet.
The problem with springs is they are not going to get super hot, in my opinion. What if you made a screw on aluminum heat sink out of sheetmetal? Make a tube, flush rivet angles onto it. They can be thin. Use heatsink compound between the angles and tube. Also use it between your aluminum tube and the exhaust. Keep volume to a minimum as extra volume will just pass cole air. I would try and make the outside of the muff a tube as well.
I will have to make sketches sometime. Hard to do that on the phone.
Bryan Cotton wrote:http://www.chiefaircraft.com/aircraft/windshields-vents/cabin-heat/la-hm1.html
