by Mike53 » Thu Oct 27, 2011 12:39 pm
I am assuming that when looking for a blade that I need to get one that has more teeth.
Chris the more teeth you have the less chance of the blade grabbing the part and throwing it .A cut-off blade has no teeth at all and you can easily hold the part with your hand but it will leave a burr .
In my opinion carbide is the way to go with at least 80 teeth if you want a smoother finish and less chance of it grabbing.Down side to more teeth is it will cut slower ,so it's a trade off. More teeth=Smoother finish and a slower cut but safer. Less teeth = faster cut and a rougher finish and clamping is always necessary if you value your fingers.
If you haven't bought a mitre saw yet it is worth looking for ones that have the clamping device built right in .Home Depot brand Rigid has such a feature. Trying to jerry-rig a clamp on a mitre saw can be a challenge sometimes.The proper tools just make the job easier and safer.I'm lucky because of my cabinet business I already have all the power tools for the job :D
Mike
Mike
Antoine de Saint-Exupery
