Sonex 1534 Photos
Re: Sonex 1534 Photos
Postby Gripdana » Sat Dec 27, 2014 12:41 am
Thanks. It is mentioned in the 2 into 1 exhaust instruction sheet. There are no specs so I had to design the shield and make it out of scrap stainless steel left over from the firewall. I did have to remove the rivets in the fuselage and match the holes. I used masking tape over the rivets before I drilled them out and marked the center with a very fine sharpie. Then I put the tape along the rivet line on the shield and drilled the holes. They lined up perfectly. I used tan masking tape that you can kind of see through.
Dana Baker
Scratch Built
First Flight March 8, 2015
Gripdana
Re: Sonex 1534 Photos-Oil Separator
Postby Gripdana » Sat Dec 27, 2014 10:17 pm
Anyone who saw the Sonex turbo installation at Airventure this year. Does this look like their oil separator instal?
Dana Baker
Scratch Built
Gripdana
Sonex 1534 Photos
Postby Sonex1517 » Sat Dec 27, 2014 11:42 pm
Dana
I shot this at the open house. See if it helps
Chicagoland
N1517S reserved
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Postby Bryan Cotton » Sun Dec 28, 2014 9:03 pm
Dana,
The engine looks great on the nose!
Postby Gripdana » Sun Dec 28, 2014 10:28 pm
Thanks I wish I could say the same for the cowl. I am struggling with it now.
Dana Baker
Scratch Built
Gripdana
Postby Gripdana » Sun Dec 28, 2014 10:41 pm
I went back and worked on the cowl a bit. I found that the relief cut I did worked out after all. The top of the cowl was very high. After taking off the hinge and trimming a little more the top laid right down. I did trim some of the aluminum from the firewall because it was binding. The only thing I can't get flush is the bottom. I did try the left side and the top seems to be a little better fit than the right. I think the right half was out side during shipping and sitting for a year it may have gotten deformed. Here are some photos of my last session. I don't really want to do the top/bottom split mod. Thanks for all the help.
Dana Baker
Scratch Built
Gripdana
Postby wlarson861 » Mon Dec 29, 2014 2:10 am
Looks like you are a little long at the firewall. The bottom of the cowl will match the bottom corner of the firewall when enough has been trimmed. On mine I thought the fit at the firewall was good but the bottom halves would not mesh. After trimming the sides and bottom more they pulled together. Take a look at Bob Meyers website he has pix of what im talking about
Bill Larson
N861SX
wlarson861
Postby Gripdana » Wed Dec 31, 2014 11:43 am
Here are some photos of the work done yesterday.
Dana Baker
Scratch Built
Gripdana
Postby Gripdana » Fri Jan 02, 2015 2:30 pm
I got the hinges installed on the cowl this morning. I still need to fill some holes on the right side to be able to do the hinge there. Also have some filling and glass for to do.
URL=https://imageshack.com/i/f02CJsGvj]Image[/URL]
Dana Baker
Scratch Built
Gripdana
Postby daleandee » Fri Jan 02, 2015 2:36 pm
Gripdana wrote:I got the hinges installed on the cowl this morning. I still need to fill some holes on the right side to be able to do the hinge there. Also have some filling and glass for to do.
Dana,
Looks really good! Persistence always pays off, if you have enough of it.
Now ... that wasn't so bad was it? OK yeah ... it probably was!
Welcome to 2015!
Dale
N319WF
81.7 Hours
daleandee
Return to Photo Album
Users browsing this forum: No registered users and 35 guests
