Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby Bryan Cotton » Tue Dec 02, 2014 12:16 am
Drilled all the 3/16" bolts. Got the upper firewall drilled on.
Have some countersinking, a boatload of deburring, and placement of the hinge on the firewall to go yet.
Postby ScottM-Sonex1629 » Tue Dec 02, 2014 1:41 pm
Bryan:
I'll quote my B-I-L:
"That looks great, if you can't make it fly it we can turn it into one heck of a BBQ smoker!"
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Postby Bryan Cotton » Fri Dec 05, 2014 12:41 am
Scott,
My former co-workers back in Stratford used to tell me I may as well put chains on my hummelbird fuselage and hang it off the swing set. I haven't proved them wrong yet!
The issue with my new flange is I had to remake this clip and add a shim:
All flush riveted up:
I have the nose torn back off for deburr. Then we can rivet.
Postby Bryan Cotton » Sat Dec 06, 2014 11:56 am
So how do you deburr the holes inside the square tubes for the floor/firewall stiffener?
I figured there was no way the file handle would bend without breaking but it was no problem.
This worked like gangbusters.
Postby Bryan Cotton » Mon Dec 08, 2014 10:45 pm
We have the forward frame of the tailcone all deburred, bolted and riveted up.
The tailcone is upside down again waiting for the nose to go back on.
Is this a good time to close out the upper crossmember? Seems like the bottom is off just so we could bolt it up but I could not find a reference on the plans to rivet it.
Postby Rynoth » Mon Dec 08, 2014 11:19 pm
I thought that was called for when finishing the Turtledeck. In any case, you'll be drilling a lot of holes in the cross tie box wheen you install piano hinges for the seat pan, so if it's still not riveted, it'll make deburring those holes easier.
Postby daleandee » Tue Dec 09, 2014 2:25 am
One of the things that was done on my cross tie box was to cut a semi circle opening in each end on the bottom cover so as to allow access to the nuts on the inside. During annual it makes checking these for proper torque much easier.
Be nice if I had a photo ...
Dale
N319WF
daleandee
Postby Bryan Cotton » Wed Dec 10, 2014 12:17 am
Here is another tool idea. There were some tight spots where I could not countersink the holes in the forward wing attach. I had this coupler and modified it by running the ID up to 1/4". Hacked the head off an AN4 bolt for one side and the microstop went into the other side.
In hindsight my angle sander would have worked too. It takes a 1/4" arbor.
Postby Bryan Cotton » Mon Dec 22, 2014 3:51 pm
The angle sander trick didn't work for me, not enough torque.
Here Adam is riveting the lower firewall while Matthew drills pilot holes in the treads of his human hamster wheel.
Upper firewall going on:
Left side:
Right side:
The nose is riveted and bolted on!
Done for today:
Postby Bryan Cotton » Mon Dec 22, 2014 7:10 pm
I started working the motor mount. It is tight to get the lower motor mount between the angles, but once you get it in it is loose.
I have the fuselage all level again. I think I will put some angles on the floor, the 4 and something inch distance as specified, then use plumb bobs. It will make more sense when I have pictures to post.
Return to Photo Album
