Pace has slowed some this December, lots of family activities always going on. I was able to spend a few hours in the garage this weekend, and have the components for the brake handle and cable guide fabricated, just need to drill the holes in the spar tunnel. Not looking forward to doing this now, wish the plans mentioned for a tri-gear this should be done prior to spar tunnel and lower skin riveting.
![Image](http://i305.photobucket.com/albums/nn218/STL-Scott/Sonex%201629/99c94be37d7ed5292ef65ededf12b600.jpg)
Making progress with the engine (intake, AeroInjector and alternator, coil triggers), and engine wiring.
![Image](http://i305.photobucket.com/albums/nn218/STL-Scott/Sonex%201629/02f2bea8b4172adb19f345c93e47c475.jpg)
![Image](http://i305.photobucket.com/albums/nn218/STL-Scott/Sonex%201629/31460bd188f66d43e4c9c8ee86be8e9a.jpg)
![Image](http://i305.photobucket.com/albums/nn218/STL-Scott/Sonex%201629/3afd8a6fa24c0fc134607e968a629015.jpg)
I've also got a good start on the panel wiring. All of the circuit breakers and + feed to the switches are done. Panel is painted and labeled, and the starter, master switch and coils are wired to firewall components. Also received a second hand throttle quadrant Friday from another forum member, trying out the location. Thanks Tom G!
![Image](http://i305.photobucket.com/albums/nn218/STL-Scott/Sonex%201629/75c5e887b822a35186b916e82e93df69.jpg)
![Image](http://i305.photobucket.com/albums/nn218/STL-Scott/Sonex%201629/5831c55e44b9bcb4e60c78354c1fbe94.jpg)
Looking forward to the holiday break...should be able to finish the wiring.
Oh, I also ordered my exhaust system and Prince P-Tip carbon fiber propellor for Christmas...the turbo will have to wait.
