Scott's Sonex 1629 - N629SX
Re: Scott's Sonex #1629 - Progress
Postby ScottM-Sonex1629 » Mon Nov 24, 2014 6:45 pm
Thanks for the feedback guys. I've flown in the cockpit several times including a few XC's in my friends Waiex with both my iPad 2 (full size) and his iPad mini. The mini with retina display works a lot better in the cockpit. So far no overheating issues with the iPad/mini. We will see how it works on the instrument panel mounted like this.
Here is a link to the mount I got from Aircraft Spruce:
https://www.aircraftspruce.com/catalog/ ... tab11u.php
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Postby ScottM-Sonex1629 » Fri Nov 28, 2014 12:34 pm
Random images of the progress over the Thanksgiving holiday.
Antennas:
Replaced the nuts with anchor nut plates for all of the firewall mounted items.
Made the final plan / location for the gascolator, and have it installed now.
Ready to hang the engine! We plan to do this on Sunday...
Scott Meyer
ScottM-Sonex1629
Postby onex28 » Fri Nov 28, 2014 3:12 pm
Thanks for the post Scott. I was about to ask the southerners and those with heated garages to post videos and progress reports. -3 yesterday morning, garage below 40 an I'm about to go bonkers from lack of activity. You did the right thing, everything on my firewall is attached with nut plates.
David
N951X (reserved)
onex28
Postby ScottM-Sonex1629 » Sun Nov 30, 2014 4:14 pm
David,
It is a balmy 62 deg F here in Ohio today. Nice day to install an engine in the Sonex! Mike Farley and Steve Stahl came over and after following Mike's advice for installing the X accessory plate on the engine mount first, the engine install was a breeze. Two guys lifting, one installing the bolts. Maybe five minutes tops.
Scott Meyer
ScottM-Sonex1629
Postby Bryan Cotton » Sun Nov 30, 2014 6:44 pm
Scott,
That is awesome! Good to see the engine up there.
Postby onex28 » Sun Nov 30, 2014 7:06 pm
Looks good Scott. Lots more room behind the engine than my Onex.
David
N951X (reserved)
onex28
Postby Rynoth » Mon Dec 01, 2014 10:16 am
Scott, great pics, very exciting and motivating! I'm taking delivery of my Aerovee Turbo kit tomorrow, your pics mounting the engine have me even more excited!
Postby ScottM-Sonex1629 » Tue Dec 02, 2014 1:49 pm
Thanks guys!
Started to populate the instrument panel late the other night...
Waiting on some new white letter tape to arrive for my label maker.
Scott Meyer
ScottM-Sonex1629
Postby Rynoth » Mon Dec 08, 2014 11:24 am
Scott, which paint did you use on your engine case, and what was your method for masking the machined surfaces?
Postby ScottM-Sonex1629 » Mon Dec 08, 2014 12:39 pm
Ryan - I used Rustoleum Engine Enamel, 500 deg F in gloss Black.
I cleaned the surfaces to be painted with Spray brake cleaner. Wiped down surfaces thoroughly. Use high quality yellow AutoBody masking tape for covering areas not to receive paint.
This paint is pretty durable and can be cleaned up with lacquer thinner.
Will see how it holds up, I've used it in the past on an aluminum engine in my kit car project.
Scott Meyer
ScottM-Sonex1629
Return to Photo Album
Users browsing this forum: Bing [Bot] and 7 guests
