Mixture travel?
Mixture travel?
Postby Bruce593SX » Thu Dec 04, 2014 11:36 pm
how far out does your mixture cable travel? I'm deciding in placement.
Bruce Johnson
Sonex 593
Bruce Johnson
Sonex 593 AeroVee Turbo
Plans building near San Antonio, TX
Bruce593SX
Re: Mixture travel?
Postby tonyr » Fri Dec 05, 2014 2:42 am
Hi Bruce,
I have to measure exactly but it wouldn't be more than 2" from full rich to cutoff.
Cheers
Tony
Sonex #813
First Flight... 4 Oct 14
298 hours having fun!
tonyr
Re: Mixture travel?
Postby Doug Raby » Tue Dec 23, 2014 7:31 pm
Hi Bruce,
I'll make one recommendation regarding the mixture cable. Do not trust the set screw that locks the cable to the aerocarb. Mine let go, thankfully it happened while I was on the ground. The solution a friend gave me was to lock wire around the coil sheathing , on both sides of the channel that it runs through the carb. I did two loops tight up against the channel using 1 piece of wire for both sides, then spun both ends together. You'll never have to worry that you've got the cable locked too tight or too loose.
Doug Raby
Users browsing this forum: No registered users and 42 guests
