LED Wig Wag Landing Lights
Postby daleandee » Mon Nov 24, 2014 8:07 pm
Postby Friesen5 » Tue Nov 25, 2014 9:09 am
Thanks for sharing this information. You did a thorough job of explaining your installation and provided the sources for the parts so that we could replicate what you've done. Question - does it create any amount of heat?
Friesen5
Re: LED Wig Wag Landing Lights
Postby daleandee » Tue Nov 25, 2014 6:57 pm
Postby rdsafe » Thu Nov 27, 2014 12:11 am
Hi Dale;
I've reviewed your information here and want to follow in your footsteps.
I have the Duckworks setup and decided to check on how I would install these lights. I took a large yogurt container which is 4.5" in diameter at the top and cut it down to 3" in length as specified on Amazon. The only way I could get it in the cutout opening was to slide it in sideways (3").
So, how did you fasten the light to the mounting bracket and get the assembly back into place.
Richard
rdsafe
Postby daleandee » Thu Nov 27, 2014 3:56 am
Postby rdsafe » Thu Nov 27, 2014 9:41 pm
Hi Dale;
The scenario you’ve spelled out is kind of what I had in mind and I just wanted to make sure it was doable with the wings assembled. Little hands and dexterity mean a lot here.
Many thanks again and a "Happy Thanksgiving" to you and your family
Richard
rdsafe
Return to Electrical System
