onex28 wrote:It's going to be trial and error Mike. What I've done is to take a piece of AL about 4x3 inches and bend about 1 inch from an edge approximately 20 degrees. Duct tape it to the underside of aileron on the light wing and fly. If it doesn't raise the heavy wing enough, increase the bend and lessen the bend if it raises the heavy wing too much. Once you have it where you want it rivet it to the aileron. Also, I put my trims in the center of the aileron, lengthwise. If you mount the trim trailing edge slightly ahead of the aileron trailing edge it's not immediately noticeable.
David
Sonerai13 wrote:Check out my video on trimming an airplane on the EAA Hints for Homebuilders site. It contains quite a few photos of trim tabs on the factory Sonex aircraft. Here' the link: http://bcove.me/pa2hjbxk
Cheers!
SonexN76ET wrote:I recently tried the trick of lowering my right flap two turns to correct a slightly heavy right wing in cruise. While this corrected the heavy right wing at cruise speed it caused the left wing to become heavy when the flaps were deployed. With the flaps deployed it also caused additional yaw during slow flight. My right flap has more play than the left flap. So, in my case, I will need to install a flap stop on my aft spar near the outboard edge of the right flap.
