Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby daleandee » Thu Oct 30, 2014 10:52 pm
Bryan,
If you keep messing around up there you are gonna wind up with an airplane!
Dale
N319WF
daleandee
Postby Bryan Cotton » Thu Oct 30, 2014 11:36 pm
Thanks Dave and Jake! We are getting there.
Edit: my iphone must think we are done. See routing options it gave me for the return from Detroit:
About the same performance as autocorrect.
Postby Bryan Cotton » Fri Oct 31, 2014 11:48 pm
There are 3 holes on the bottom that get drilled through a lot of stuff- splice plate, shim, channel, and bottom tailcone skin. Now that those holes are all drilled to #30, I need the same 3 holes in the cockpit floor skin. Started with a piece of scrap and transferred the 3 holes from the shim to the scrap. I clecoed the scrap to all that stackup I mentioned. Then I picked up 3 holes along the longeron by drilling up from underneath.
Now I put the front skin down and put the tool over the top:
Then I transfer the holes:
On the dents thread, I hope nobody thought I was serious about grand champion. Means a lot more to me to build it with my kid. Plus this thread is mostly trick photography.
Postby Bryan Cotton » Sun Nov 02, 2014 6:37 pm
Forward tunnel zee clecoed in:
Postby Bryan Cotton » Mon Nov 03, 2014 12:02 am
Anybody else see this? Inquiry into Kerry.
Postby Bryan Cotton » Mon Nov 03, 2014 1:54 pm
Regarding that prior picture, I am thinking a tapered shim for the gap between the angle and tunnel at the bottom. They will mate flush below the hole, but there is a gap closer to the floor. This would make the tunnel narrower here, but is there any spar in that part of the tunnel?
Postby tonyr » Mon Nov 03, 2014 5:35 pm
Hi Bryan,
Looks like you just need to tweak the F14 angle a little more in the bottom corner?
Should be easy to do with an adjustable spanner and the spar tunnel removed.
Not sure what you're talking about re the tunnel being narrow but there is no spar in the lower portion when assembled.
Regards
Tony
Sonex #813
First Flight... 4 Oct 14
298 hours having fun!
tonyr
Postby Bryan Cotton » Mon Nov 03, 2014 7:32 pm
Thanks for the reply Tony. Sonex tech support suggested checking the angle as well. I put a straight edge across the two front angles and they seem pretty darn coplanar.
Postby Bryan Cotton » Mon Nov 03, 2014 7:46 pm
So, if I cleco my forward zee to the forward wing mount angles, leave the floor unclecoed, and use a fine tip sharpie through the floor hole this is what I get:
True on both sides.
Postby Rynoth » Tue Nov 04, 2014 8:35 am
Bryan, how is the fitment of the aft tunnel zee if you test its position relative to the floor pilot holes and aft wing attach angles?
If you cleco the forward zee to the forward angles, and cleco the forward zee to the floor near the center, do you end up with a bow in the forward zee as you look through the spar tunnel?
Return to Photo Album
