I was going to try and mount the tail surfaces and paint it all in place, minus the control surfaces...and immediately after bolting down the horizontal stab, realized a flaw in my plan. The vertical stabilizer is installed after the elevator is rigged to the HS. Oops.
So tonight, I decided to go back to my original plan, paint these surfaces all separate, and off the fuselage. Time to make a few rigging stands. Some scrap wood, screws, and Bob's your Uncle.
![Image](http://i305.photobucket.com/albums/nn218/STL-Scott/Sonex%201629/04f75a6502b57a008efcd8cc98b56742.jpg)
![Image](http://i305.photobucket.com/albums/nn218/STL-Scott/Sonex%201629/d3186c2fff1df57099651bfb64a00e12.jpg)
Now for you aspiring painters out there, if you are spraying a metallic or pearl paint, you would want to have the horizontal stabilizer "horizontal" and not vertical as I have it. It's important to paint items in the orientation it will finally be when it's done.
I am using a solid red, no flake or pearl...so final orientation is not important. Also bought materials today to make a mini paint booth
