VW conversion engine facts and know-how
Postby dubbedually » Mon Dec 16, 2024 6:30 pm
Starting this off trying to find as much info about vw engine modification for flight application and how different it is in comparison to vw racing engines… i.e is there no turning back once a case and all has been modified or could one use them interchangeable?
Would a turbo set of duals for a 2000cc car application work after it’s been used in a bird.
There has to be some type of cooling issue I’d imagine
Also if these a/c (aircraft) versions would work in a car would this one (picture provided below) be worth it if it checks out for 1,500 usd weighing in at 2000cc?
dubbedually
Re: VW conversion engine facts and know-how
Postby BRS » Mon Dec 16, 2024 10:54 pm
Looks like that is sitting in a gyroplane, no?
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Postby dubbedually » Tue Dec 17, 2024 12:09 pm
I believe it very well could be. The seller does have a gyroplane listed.
dubbedually
Postby Bryan Cotton » Tue Dec 17, 2024 2:11 pm
That does not look like a VW Type 1 case. So I guess the first question is, what is it?
Postby Dave Wolfe » Tue Dec 17, 2024 6:14 pm
Im not an expert by any means but it seems to resemble a vw type 4 engine
Dave Wolfe
Postby karmarepair » Tue Dec 17, 2024 7:48 pm
Dave Wolfe wrote:Im not an expert by any means but it seems to resemble a vw type 4 engine
Concur, it's a Type IV. And the nose of the "Fan" end of that crank has a short, steep taper that makes it unsuitable for a prop hub attachment. Steve Bennett of Great Plains tried to make this engine work and an internet acquaintance of mine put one in his KR-2 and it almost killed him. Steve stopped cataloging parts for Type IV engines. You MIGHT be able to make this engine work as a flywheel drive, but the aluminum case is substantially heavier than a Type I, so why bother?
As I've said for decades, if you think the airframe you want to use needs more than about 70 - 80 continuous horsepower, you should be looking at some other engine.
karmarepair
Postby Bryan Cotton » Tue Dec 17, 2024 8:43 pm
I think he wants to buy that motor and put it in a car.
Postby dubbedually » Wed Dec 18, 2024 9:27 pm
That would be a correct statement Bryan.
dubbedually
Return to Other Engines
Users browsing this forum: Google Adsense [Bot] and 2 guests
