Seems my uneven flow is based upon a rookie mod. After lots of thread reading and a quick conversation with Joe at Revmaster is seems clear (is that an oxymoron using 'seems' & 'clear' together?) that I oops-ed when creating my ram-air induction. I had read some about ram-air not working with the AeroInjector but seeing and mis-interpreting the picture/info on the Revflow carb let me to think that for some reason ram air would be fine.
RevFlow pic shows a cold air intake valve exposed to ram-air. BUT since that ram-air is free to exit in reverse flow (inside to outside) through the filter it does not really increase the MAP thus it's not pushing the fuel backwards at the needle.
- revflowass.jpg (42.56 KiB) Viewed 9937 times
The symptoms I've been having make sense now. On takeoff I was experiencing what seemed to be very lean conditions while the jet is clearly adjusted very rich. Soon I'll have this all sorted out by eliminating the ram-air or perhaps later installing a balance tube from ram-air to the fuel tank. For now I'm going to go with just a filter in warm air and block the ram altogether.
