Onex wrote:With a filter they say 50 hours is required/allowed. It isn't dirty oil that is the problem, it's the buildup of acidic products from the NOX gases that eats your cam shaft. Change oil more often and don't rely on the filter to "purify" your oil.
rizzz wrote:Then I came across a post from the late Bob Hoover, on the topic he said: " Do you know of any modern engine that does not incorporate full flow oil filtering?"
radfordc wrote:rizzz wrote:Then I came across a post from the late Bob Hoover, on the topic he said: " Do you know of any modern engine that does not incorporate full flow oil filtering?"
Does any modern engine require oil changes every 25 hrs?
SonexN76ET wrote:There have been numerous reports of people with Aerovees and other VW conversions using external oil filters who have blown the oil filter seal and or oil line to the filter. Sonex firmly warns against an external filter. The oil filter sold by Aero conversions is for use with the Aerovee turbo and sits inside the engine sump.
Anytime you make a modification to your engine, especially one warned against by Sonex you are taking a huge risk.
For me, I want my flight risks to be as low as possible.
