I'm going well rebuilding my engine but I've run into something I'm a little concerned about.
I installed the various block-off plates, and the case breather last night, however I'm a little concerned about the height of that breather, I fear it won't fit under the cowling.
You can see it sticks out 2" above the case:
For the Sonex builders out there:
How much room is there under the cowling in that area? Would this breather fit? (It's hard to make out from the plans.)
If not, what are the options? I noticed Great Plains sells a lower profile breather, any others?
