daleandee wrote:Funny really ...
When he was trying to sell it on Barnstormers there was no mention of any of this. I also wonder if he realizes that on his web site in his own words he says of this exact airplane, "Viking Waiex - 160 mph cruise and a BLAST to fly." That quote and the photo of the plane is here (1/2 way down the page):
http://www.vikingaircraftengines.com/sonex.htm
So he was either lying then or now ...
Dale
N319WF
Don Bowen wrote:Whether or not you like Jan and/or the Viking engine, I think there is something wrong with this aircraft, not the Sonex/Waiex Viking combination.
rizzz wrote:BTW, Does anybody know the history of this Waiex? I can't quite read the registration from the picture on his website.
Would be good to know whether it had any issues flying with the original AeroVee engine.
daleandee wrote:rizzz wrote:BTW, Does anybody know the history of this Waiex? I can't quite read the registration from the picture on his website.
Start here:
http://registry.faa.gov/aircraftinquiry ... ertxt=65yx
Then follow it to here:
http://www.wysk.com/index/florida/edgew ... lc/profile
Then click the "officers and directors tab":
http://www.wysk.com/index/florida/edgew ... c/officers
and then click on Jan's name:
http://www.wysk.com/search/doEntitySear ... GENFELLNER
This confirms the tail number of N65YX and that it was Aerovee powered.
Take that to the Sonex site:
AAArrrrrhhhh ... I cannot get a link to work but search builders under Waiex serial number 65.
A search of the NTSB database for "Waiex" model show 5 accidents and none with that tail number. Sonex shows the builder as Shayne McDaniel and the current owner as Jack Nelson. The FAA registration does show the new owner as pending but I thought it said that back when it was on Barnstormers. But in reality all of this really says nothing at all.
Jan may want to contact the FAA before he takes off in that airplane again as the FAA data base puts up a warning before you get to the registration that reads; "This aircraft's registration status may not be suitable for operation."
FWIW,
Dale
N319WF
fastj22 wrote:Got to thinking about changing the wing incidence on an already rigged airplane. If only moving the rear spar measurement, that would put twist strain on the main wing bolts and spar. So the proper method would be to replace the entire spar box and fuselage supports along with the rear spar carry through and re-drill for the bolts to the new alignment. This is not minor, but a huge undertaking.
rizzz wrote:fastj22 wrote:Got to thinking about changing the wing incidence on an already rigged airplane. If only moving the rear spar measurement, that would put twist strain on the main wing bolts and spar. So the proper method would be to replace the entire spar box and fuselage supports along with the rear spar carry through and re-drill for the bolts to the new alignment. This is not minor, but a huge undertaking.
Ken wrote:I think this is a trim thing not balance because tried putting 8 pounds on lead on the tail wheel it had no effect at all my sonex dose have the same issues
Steve wrote:Opinion. You are probably producing near Jabiru power, maybe a little more. I have not heard of Jab Waiex'es with such control issues.
This aircraft was not built by you. It just doesn't sound like this airframe is right....and if it is not, it is probably in the tail.
Or, very aft CG.
It certainly wouldn't take much.
Don wrote:I am curious about this. You are running about the same speeds as the Jab 3300 powered planes, but they don't seem to be reporting this issue. Can you trim it out? Or are you changing the angle of engine mount or wing incidence? Is this as serious as Jan makes it sound or is it something that can be lived with. Just trying to figure out what is ahead of me with this project.
Ken wrote:No its not a big deal just trying to make it better my plane flys hands off a crus you beed ruder input with power above 5,000 rpm or below 3200 its just could be better i hear other sonex air craft can't take thier hands off so i think my sonex flys grate just would like 2 deg left trust that way i would not need left ruder on take off and right ruder in descent
Viking wrote:Well, you can't live with the airplane climbing when you want to stay level. So you do need enough trim to hold it level.
You can have this if you increase the forward spring force, but it will proportionately lessen the amount available for up trim when flying slow.
So, you end up holding the stick back during the entire approach and landing.
The system is not capable of trimming the speed range from 40-170mph
This might have to do with:
- The large flyable speed range
- Inherent to the type of airfoil
- The V-tail being less powerful, hence the trim less powerful
- The trim system is inadequate for the job (not enough range
I have now added two external tabs to the airplane, one on each ruddervator. However, I believe a more powerful spring system would have less drag
Viking
Ken wrote:Yes stronger springs on the trim would deftly help im going to do that !!!!
Users browsing this forum: Bing [Bot] and 17 guests
