Over Voltage Protection Device
Postby JFYrineo » Mon Apr 08, 2024 6:35 pm
I am trying to find out what others are using for an OVPD out there. I have a new Jab3300 Gen4 install on my SonexB. B&C doesn’t seem to have a current working solution. When I contacted Nick at Arion Aircraft to ask what Jab uses on their airplanes and his Arion Lightings with Jabs he said just the voltage regulator with a fuse on the main bus.
JFYrineo
Re: Over Voltage Protection Device
Postby n502pd » Tue Apr 09, 2024 6:23 pm
What protection are you after, one that blows the fuse thats in line, or something else. I ask because, years and years ago, in my Triumph and BSA cycle days, they had a very large zener diode across the buss, and mounted on a big heatsink that would keep the buss voltage at a level that woild not hurt whatever was connected to the buss. the same principle might be applied here?
Joe Nelsen
scratch built :D
Flying @78.2
KGYI/N. Tx Reg/Perrin Field
n502pd
Postby JFYrineo » Wed Apr 10, 2024 6:11 am
The OVPD senses an over voltage situation out of the PM alternator and sends the current to ground by de-energizing the coil in the alternator relay
JFYrineo
Return to Jabiru
Users browsing this forum: Bing [Bot] and 3 guests
