Oil Pressure Sender
I've replaced the oil pressure sender quite a few times in 450 hours on my Jab 2200. I've also mounted it remotely in order to reduce mechanical movement which could lead to early failure. My current sender indicates a non running pressure of 1 PSI.
I see that Aircraft Spruce has a solid state oil pressure sender that may replace the VDO. https://www.aircraftspruce.ca/catalog/i ... ey=5678474
I have a GRT Engine Monitor (4000). Do any of you have any experience in making this change? What settings need changing on the GRT? How about the wiring?
Thanks!
Mervin Friesen
Thanks!
Mervin Friesen
