752mr wrote:Isn't there a simple way to test the charging system components?
Fly it!
Sorry to sound snarky, couldn't resist, but that will really be the best way. Remember, the battery will not even charge until you get up into the low 13 volts. Most battery tenders run about 13.2 volts. You won't see that until you are at flying RPM's.
During your Aerovee ground setup, if you want to run the engine briefly at WOT - which is OK for a short time - make it a check off item to view the voltage output. If you are unhappy with the number, be sure and double check the voltage with a good voltmeter. Those tenths of volts will matter.
On the ground, even during WOT you will still see lower voltage than in the air because the battery is recovering from the cranking drain. Be happy that the number is rising. That will mean the full amperage of the alternator is starting to recover the battery. The voltage will slowly rise as the battery charge builds. In the air, don't expect to see above 14 volts, more like 13.8 max.
It takes a good long flight for the battery to recharge - and reach max voltage - with the Aerovee alternator. If you fly 30 minutes at a time you will not recover to a full charge. An hour at normal cruise seems to be more than enough however.
Here are some plots of recent flights. Add 2.2 volts to the plot numbers. The MGL tool I use for the Enigma records the raw data not the calibrated displayed number.
The First is for about a one hour cruise flight and the second is for some pattern work. Note the steady drop in max voltage in the pattern work plot.
- Aerovee Voltage Typical.JPG (102 KiB) Viewed 5118 times
- Aerovee Voltage Pattern.JPG (98.92 KiB) Viewed 5118 times
