Fuel Flow
PostPosted: Mon Apr 07, 2014 11:01 pm
by mike.smith
I just did a fuel flow test of my Sonex tail dragger in the parked position. If anyone wants to check my math:
- 1 gal came out in 82 seconds
- Flow(GPH) = 3600 X #Gallons/#Seconds
- 3600 x (1/82) = 43.9 gph
At 0.55 lbs per HP, the Aerovee should burn:
- 0.55 lbs x 80 hp = 44 lbs/hour
- 44/6 lbs (avgas) = 7.33 gph (wide open throttle)
FAA says design for 150%, so...
- 7.33 ghp x 150% = 11 gph
So at 43.9 gph I think I have enough fuel flow ;)
Next I need to check with a steep (25 deg) climb angle.
Re: Fuel Flow
PostPosted: Tue Apr 08, 2014 9:32 am
by radfordc
Sounds good. Check at a steep angle and with only a few gallons in the tank to get worse case.
Re: Fuel Flow
PostPosted: Tue Apr 08, 2014 10:39 am
by Fastcapy
Re: Fuel Flow
PostPosted: Tue Apr 08, 2014 2:46 pm
by GordonTurner
I'm not sure how to factor it in, but nose high the bottom of the tank might be able to show higher flow, but it will also have less height above the carburetor which is below but far forward of the tank outflow.
Re: Fuel Flow
PostPosted: Tue Apr 08, 2014 4:20 pm
by radfordc
The bottom line is that if you are in a steep nose up attitude you normally need full power. In a steep nose down attitude...not so much.
