Any other safety tips?
With the ground for each plug being the engine block the plugs are in parallel
HI Scott,
I do understand the basics of how a step up transformer works. Just so I understand, when you say "dual output coils both spark plugs will share a common secondary winding" does that mean that the same circulating current in the secondary flows through both plugs? Does it mean that the two spark plugs are basically in series with the single secondary? I understand arcing to the core, but what does arcing " internally" mean? Primary to secondary? I'm just confused.
Wes
Scott Valentine (Dynatek)
Feb 28, 2024, 1:13 PM PST
Correct, one end of the winding is connected to one spark plug output and the other end is connected to the other plug output. Both plugs fire at the same time with the majority of the voltage going to the cylinder under compression. As for the arcing I was just giving possible scenarios. Without witnessing it I cannot really say where it was arcing to. I would just try to avoid that situation altogether.
Regards,
Technical Support
Toll Free: 800-928-3962
