Area 51% wrote:Wires going to the correct cylinders?
Holmesryan wrote:Area 51 and others-
Top mag goes to front top cylinders should top wire go to x and the bottom wire go to x.
Bottom mag goes to the top rear cylinders, same equation as above?
Just as a follow up plugs all new, I checked and there is spark and I regapped the mags.
Re-grounded everything
Ran both mags p leads off, each time engine ran the same.
Holmesryan wrote:Top mag goes to front top cylinders should top wire go to x and the bottom wire go to x.
Users browsing this forum: No registered users and 135 guests
