EMPI Full-Flow High Volume Oil Pump and Filter unit
Re: EMPI Full-Flow High Volume Oil Pump and Filter unit
Postby karmarepair » Fri Mar 29, 2024 11:44 am
I'm having a little trouble parsing your last sentence, but I think what you're saying is you're going to try the EMPI cover/filter with the bypass valve on a 26mm pump.
If so, I like this idea.
I have always been skeptical of these filter/pumps; knowing the EMPI unit has a bypass makes me more likely to try one.
karmarepair
Postby Area 51% » Sat Mar 30, 2024 6:54 am
Be sure to map-out the passage holes on the cover versus the holes in the body. They don't always match up with different brands of pumps. I had to elongate the hole in one to match the hole in the other.
Area 51%
Users browsing this forum: Bing [Bot], Waiex 0194 and 6 guests
