Sonerai13 wrote:Nothing mysterious about this.
daleandee wrote:It is supposed that the difference in the cooling set up (oil cooler on top) is causing pressure differences in that area that will require a seal?
daleandee wrote:PS: BTW, Sonex could have fun with this on April 1st ...
Sonerai13 wrote:No, it's not really that. We have the top-mount oil cooler on several factory prototypes now, and none of them experience any leakage due to the installation of the cooler. Like I said, it is just an experiment. :)
rizzz wrote:Is there any particular reason Sonex is experimenting with mounting stock vw (I think) oil coolers on top now on Sonex/Waiex aircraft instead of the standard bottom mounted oil cooler setup?
I thought this was only done on the Onex because of clearance issues?
Is there anything better/worse about this setup?
Sonerai13 wrote:The top-mount cooler might also make cowl installation easier if you decide not to put the little "mouth" below the prop spinner, and thus won't have to make and install the pan below the oil sump. That's how we did the new cowl on the Waiex, which some of you saw at Crossville.
