Bryan Cotton wrote:Cool! This optimizing is equal parts fun and hassle.
pfhoeycfi wrote:I added deflectors to my B exits which solved my heat issues. I took manometer readings with and without and the PD from inlet to outlet Increased significantly with deflectors. Not quite the same issue but something to consider nevertheless.
tps8903 wrote:pfhoeycfi wrote:I added deflectors to my B exits which solved my heat issues. I took manometer readings with and without and the PD from inlet to outlet Increased significantly with deflectors. Not quite the same issue but something to consider nevertheless.
Excellent info Peter. Do you have the dimensions and or pictures etc of those deflectors?
pfhoeycfi wrote:Pic
