daleandee wrote:I'm going to politely disagree with this. Your voltage reading is showing what is coming out of the regulator. If you want to know battery voltage you will see it before engine start or when shutting down the alternator in flight. At very low RPM your voltage may show what the battery voltage is if the alternator is not putting out more than the battery voltage. But at 2700 RPM you are seeing the voltage the regulator is sending out to the system.
You don't have to be polite to disagree as it's not impolite to disagree. Some people on the other hand are (not you)..... Anyway.
Perhaps I was imprecise. When I said 'battery voltage' what I really was thinking was 'charge voltage'. Good for calling me out. With that said I stand by my assesment but I'd better be more clear about what I'm thinking as the typed text is not always true to my thoughts.
The flow of current (my sonex as an example with a revmaster) is from the
alternator ---> regulator ----> battery. Between the regulator and battery is where I measure voltage and current. It's the same voltage right on the battery positive post. With the regulator/alternator switched off, there exists only battery voltage. Something like 13.3v on an EarthX battery. But at the exact same positive battery post, once the alternator is switched on, the voltage begins to climb to the regulator voltage. This is as long as other power consumers (lights, ignition, pumps, etc) don't exceed available alternator current. So when I speak of battery voltage what I really mean is the voltage on the positive battery post, regardless of it's charging state. Thus if you have an alternator overloaded that voltage might be 12.7 volts or it might be 14.5 volts if the alternator is putting out full current and is not over loaded. It's this voltage that a solid state ignition will normally see.
To the origanal question of powering an electronic ignition, I'd be concerned with how long the battery, without the alternator, can sustain the ignition and any other required items to keep the enging going.
Keep in mind,
the airframe (pumps, lights, radios, etc) all (normally) run on the alternator current not the battery voltage.
