by pappas » Sun Jan 29, 2023 8:37 pm
The #3 needle is probably rich enough. I used it during the break-in and went back to either the 2.5 or 2, (can't recall right now). I used the Prince, Sensenich cruise and climb, and an Ed Sterba cruise. The prop didn't make a difference in temps for me.
I read somewhere that to get an estimate of the maximum fuel burn your engine should see is to divide the HP by 11.5. 100/11.5 = 8.69. I easily saw over 8 gph at max takeoff. The indications are that you are a bit lean. Leave the needle alone and adjust a bit richer. Regardless, you will still see higher temps in the first 25 hours. Only count the flight hours for this process and don't forget to lean some for smoothness above 3000 ft DA.
You might notice them a bit better after 15 flight hours. Ground running doesn't help you and should be minimized. Fly it. Circle the field at 2500agl until you feel comfortable. I was there for 3-5 hours before I ventured too far from home.
For some of us, #3 is the hottest and for others #1. Mine was #3. Go figure. A few outliers have 1 or 4 as the hottest CHT but that is less common. I don't think any of us get the CHTs closer than 20 degrees between the hottest and coldest. It is after all still a VW-based engine. In the 250,000 miles that could be put on a 1969 VW, not for one minute of that time did anyone know what their CHT or EGT was! Just a light for the OP. And that one would always flicker at idle!
Adjust a little richer, don't be afraid of the extra fuel burn during the first 50, fly it, and have fun near home until you have the confidence in it you will certainly find. Let us know when the temps come down. Everyone has the high temp, new engine blues. Then they go away.
pappas on Tue Jan 31, 2023 6:28 pm, edited 1 time in total.
Lou Pappas
Phoenix, AZ
RV-7A (Building)
Waiex B Turbo
RV-8
Waiex Legacy 3300
Hiperlight SNS-9
Falcon Ultralight[/b]
