by 8pointroll » Thu Nov 28, 2013 11:37 pm
These postings regarding wiring an ACS ignition switch could not have come at a more opportune time for me because I have been scratching my head on how to do it properly. I understand the comments but would appreciate it if any of you who have installed the ACS ignition switch could take a few minutes to provide some additional clarification. I specifically would like to know which diodes and relay to use, the proper orientation for the diodes and how to wire the relay and diodes to the switch. My switch has the starter position as well.
Also, did any of you route any of your wiring through what I think are ferrite cores to eliminate interference and if so, what wires, what cores and how is it done.
Thank you all in advance for your time and assistance.
Best,
Stuart Leibovitz
781-985-2775
Sonex 1106, aerovee, tri gear, D180, AP, electric flaps, aerovee disc brakes, homemade smoke, cabin heat, canopy lift strut, horizontal split cowling, 90% done 80% to go
